Linux image "/usr/local/" folder is empty
nataut
Hello everyone
The "bitbake <my_recipe>" process ends without errors but the "/usr/local/" folder of the image is empty (there are no ST demo folders and no "weston-start-at-startup" folder). Why?
nataut
@Erwan SZYMANSKI
Thank you for your availability. I cleaned and rebuild the yocto image and now the "/usr/local" folders are present.
Many thanks
7 REPLIES 7
Erwan SZYMANSKI
Hi @nataut ,
What is the image you compiled ? Because here you tell me about a bitbake recipe compilation, but do you compile the complete image provided by ST ? Or did you make your own image ?
Whatever, you have to know that everything installed inside /usr/local in Yocto is overwritten by the userfs recipe.
To take an example, I invite you to take a look at /meta-st/meta-st-stm32mp/recipes-st/images/st-image-userfs.bb. I think it will help you to understand how to manage your userfs part with Yocto.
Kind regards,
Erwan.
nataut
Hello @Erwan SZYMANSKI
I'm talking about a Yocto image with bsp openstlinux-4.19-thud. Until now those folders were always created. I haven't changed anything in the meta-st layer. In the last build I only changed my own device tree.What can be the reason? What should I check?
Many thanks
Hello @nataut ,
ST does not support nor openstlinux-4.19 or openstlinux-5.4 anymore. I highly advice you to upgrade your OSTL version to 4.1 to get support.
Kind regards,
Erwan.
nataut
It is difficult for me to update the openstlinux version.
I think my question is a general one that applies to the other versions as well.
Can anyone help me?
@nataut ,
Do you build st-image-weston as your complete image ?
Kind regards,
Erwan.
nataut
@Erwan SZYMANSKI
Many thanks
@nataut ,
Thanks for your quick feedback.
Kind regards,
Erwan.
In order to give better visibility on the answered topics, please click on 'Accept as Solution' on the reply which solved your issue or answered your question.
