2023-05-11 08:58 AM - last edited on 2023-07-13 07:35 AM by Kevin HUBER
Than try to use this board with Debian Linux + Xorg happened strange behaviour: after one hour screen disabled forever.
No any warnings or errors in dmesg.
This issue reproduce on kernel from STLinux (5.15.67).
Also these steps make same behaviour:
echo 1 > /sys/class/graphics/fb0/blank
echo 0 > /sys/class/graphics/fb0/blank
2023-05-17 06:55 AM
Hello @BVino.1 ,
It let me think about something that I have already seen with fbdev use.
Can you check the following patch to see if it changes something for you ?
Kind regards,
Erwan.
2023-05-17 06:55 AM
Hello @BVino.1 ,
Kind regards,
Erwan.
2023-05-20 05:54 AM
Hi @Erwan SZYMANSKI I already received this patch from github community of ST, this works perfect.
Thank you for your time,
Best,
Boris
