2020-07-30 6:40 PM
Creating openstlinux-5.4-dunfell-mp1-20-06-24 distribution installation,
with bitbake st-image-weston, error rises:
(..layers/meta-openembedded/meta-oe/dynamic-layers/meta-python/recipes-extended/mozjs/mozjs_60.9.0.bb:do_compile) failed with exit code '1'
Need help
2020-08-04 4:49 AM
Hello @tpeng.1 ,
May I ask you to make a screenshot of the error ?
Armand
2020-08-04 6:03 PM
2021-11-25 9:52 AM
Have the same issue on two different machines on the last disti from 2021/11. Trying to build for QT.
2021-12-10 1:06 AM
Hi,I have the same problem as you.Here is a partial log.
| make[3]: Leaving directory '/home/migu/codesource/edk2_source/openstlinux-5.10-dunfell-mp1-21-11-17/build-openstlinuxeglfs-stm32mp15-disco/tmp-glibc/work/cortexa7t2hf-neon-vfpv4-ostl-linux-gnueabi/mozjs/60.9.0-r0/build/js/src'
| /home/migu/codesource/edk2_source/openstlinux-5.10-dunfell-mp1-21-11-17/build-openstlinuxeglfs-stm32mp15-disco/tmp-glibc/work/cortexa7t2hf-neon-vfpv4-ostl-linux-gnueabi/mozjs/60.9.0-r0/firefox-60.9.0/config/recurse.mk:73: recipe for target 'js/src/target' failed
| make[2]: *** [js/src/target] Error 2
| make[2]: Leaving directory '/home/migu/codesource/edk2_source/openstlinux-5.10-dunfell-mp1-21-11-17/build-openstlinuxeglfs-stm32mp15-disco/tmp-glibc/work/cortexa7t2hf-neon-vfpv4-ostl-linux-gnueabi/mozjs/60.9.0-r0/build'
| /home/migu/codesource/edk2_source/openstlinux-5.10-dunfell-mp1-21-11-17/build-openstlinuxeglfs-stm32mp15-disco/tmp-glibc/work/cortexa7t2hf-neon-vfpv4-ostl-linux-gnueabi/mozjs/60.9.0-r0/firefox-60.9.0/config/recurse.mk:32: recipe for target 'compile' failed
| make[1]: *** [compile] Error 2
| make[1]: Leaving directory '/home/migu/codesource/edk2_source/openstlinux-5.10-dunfell-mp1-21-11-17/build-openstlinuxeglfs-stm32mp15-disco/tmp-glibc/work/cortexa7t2hf-neon-vfpv4-ostl-linux-gnueabi/mozjs/60.9.0-r0/build'
| /home/migu/codesource/edk2_source/openstlinux-5.10-dunfell-mp1-21-11-17/build-openstlinuxeglfs-stm32mp15-disco/tmp-glibc/work/cortexa7t2hf-neon-vfpv4-ostl-linux-gnueabi/mozjs/60.9.0-r0/firefox-60.9.0/config/rules.mk:442: recipe for target 'default' failed
| make: *** [default] Error 2
| WARNING: /home/migu/codesource/edk2_source/openstlinux-5.10-dunfell-mp1-21-11-17/build-openstlinuxeglfs-stm32mp15-disco/tmp-glibc/work/cortexa7t2hf-neon-vfpv4-ostl-linux-gnueabi/mozjs/60.9.0-r0/temp/run.do_compile.125444:1 exit 1 from 'exit 1'
ERROR: Task (/home/migu/codesource/edk2_source/openstlinux-5.10-dunfell-mp1-21-11-17/layers/meta-openembedded/meta-oe/dynamic-layers/meta-python/recipes-extended/mozjs/mozjs_60.9.0.bb:do_compile) failed with exit code '1'
