Maximum value of PWM period
‎2021-09-16 4:39 AM
Hi all,
I have configured TIM1_CH3N as a pwm channel.
I am trying to do some PWM functionality here.
I am following current tutorial here. When i tried to provide a period of 10 sec it fails to take up the value.
I get following error :
root@stm32mp157a-visionsom-rgb-emmc-mx:/usr/local/firmware_demos# echo 10000000000 > /sys/class/pwm/pwmchip4/pwm2/duty_cycle pwm2
sh: write error: Invalid argument
100000000
Is there some limit to what value we can provide here?
STM32MP15 Lines
TIM
‎2021-09-16 11:19 PM
this is a Linux framework limitation which is using a 32-bits parameter with fixed 1us resolution. So maximum period and duty_cycle are 2^32, i.e. about 4.3 seconds.
I'm not expert, but there is probably other way under Linux (e.g a task started every 1 second which will then manage a GPIO)
Another solution (e.g. if you want TIMx specific features like multichannel, inverted output, etc...) is to handle the TIM with Cortex-M4, then you have full management of TIM count-clock/prescaler/counter/etc...
Regards.
In order to give better visibility on the answered topics, please click on 'Select as Best' on the reply which solved your issue or answered your question. See also 'Best Answers'
‎2021-09-16 8:23 AM
Haven't looked in detail at STM32 you are using, but possibly PWM limited to counter (16bit=65535), with prescaler (16bit=65535).
Increase the prescaler (16bit) for slower counting, or change the PWM clock source.
i.e. 100000000 = 10000*10000 = Prescale 10000 * Period 10000
i.e. 100000000 = 50000*2000 = Prescale 2000 * Period 50000
etc.
i.e. .
‎2021-09-16 6:04 PM
Seems to be a good cubemx opportunity to improve....
‎2021-09-16 11:02 PM
Hi @Community member​ : Thanks for response. It seems that on Linux front one does not have much control over these. I believe this can be controlled finely on the bare metal front. I am looking for a solution on the Linux front.
Regards.
‎2021-09-17 12:28 AM
Hi @PatrickF​ Thanks for the clarity. I will use these inputs to solve things at my end. This really helps.
‎2021-09-30 3:18 AM
Hi @PatrickF​ : Thanks for the answer. Coming back to it , is there lower limit too? I can't seem to set the PWM period for 10ms. It shows up response as Device or resource busy and further going down to 1ms , it straight away says invalid argument.
