2021-09-30 3:24 AM
Hi all,
Referring to previous discussion I had.
I just want understand what are the PWM limits for STM32MP1.
I can't seem to generate PWM signal below 100ms.
Any inputs will be appreciated.
My target frequency is 1KHz.
https://community.st.com/s/question/0D53W000014y9ZzSAI/maximum-value-of-pwm-period
2021-09-30 5:20 AM
not tested, but have you tried to ensure duty_cycle is always smaller than period ?
I have tested TIM1 using pwm-leds like described here https://wiki.st.com/stm32mpu/wiki/TIM_device_tree_configuration#TIM_configured_in_PWM_mode
&timers1 {
/* status = "okay"; */
/* spare all DMA channels since they are not needed for PWM output */
/delete-property/dmas;
/delete-property/dma-names;
/* define pwm1 label */
pwm1: pwm {
/* configure PWM pins on TIM1_CH1 */
pinctrl-0 = ;
pinctrl-1 = ;
pinctrl-names = "default", "sleep";
/* enable PWM on TIM1 */
status = "okay";
/* PWM DT user on TIM1_CH1: "pwm1", tim1_test with "pwm-leds" */
pwmleds {
compatible = "pwm-leds";
tim1_test {
label = "PWM-TEST";
/* Use pwm1 channel 0 (e.g. TIM1_CH1) */
/* period in nanoseconds (***), normal polarity (0) */
pwms = ;
max-brightness = ;
default-trigger = "default-on";
};So, not really similar to your case (here period is fixed in DT and I think cannot being changed using sysfs), but behind it is using same timer driver.
With brightness at 127 (50%), I end up to:
root@stm32mp1:~# echo 127 > /sys/class/leds/PWM-TEST/brightness
root@stm32mp1:~# cat /sys/kernel/debug/pwm
platform/44000000.timer:pwm, 4 PWM devices
pwm-0 (tim1_test ): requested enabled period: 1197 ns duty: 596 ns polarity: normal
pwm-1 ((null) ): period: 0 ns duty: 0 ns polarity: normal
pwm-2 ((null) ): period: 0 ns duty: 0 ns polarity: normal
pwm-3 ((null) ): period: 0 ns duty: 0 ns polarity: normalRegards,
2021-09-30 5:20 AM
&timers1 {
pwm1: pwm {
pinctrl-0 = ;
pinctrl-1 = ;
status = "okay";
pwmleds {
tim1_test {
label = "PWM-TEST";
pwms = ;
max-brightness = ;
