2024-02-08 12:44 PM
I used this post https://community.st.com/t5/stm32-mpus-products/stm32mp151aac-custom-board-kernel-not-starting/td-p/587192 to figure out how to add interrupts to pmic and got my board to finally boot into Linux. I then added my ethernet to the dts and now there is a conflict on PA0. The ethernet uses that pin but the interrupt is set as <&exti 55 IRQ_TYPE_EDGE_FALLING> just like most of the eval boards. I saw some use A0 gpio for the interrupt. How do I fix this?
2024-02-08 01:42 PM
Switched it to 57, found the mapping of exti to pwr_irq to gpio in stm32mp151.dtsi
2024-02-08 01:42 PM
