2024-06-24 1:15 AM
Hello all,
I'm working with STM32MP135F-DK board and GC2145 camera that comes with it. My main purpose is to get the image and save it. I tried to use the following documents for this:
https://wiki.st.com/stm32mpu/wiki/STM32MP13_V4L2_camera_overview#Grab_a_raw_frame
I didn't know how to do the "3.1-kernel configuration" step in the first link. So I followed the links below:
https://wiki.st.com/stm32mpu/wiki/Menuconfig_or_how_to_configure_kernel
After this link, I went to the following link:
https://wiki.st.com/stm32mpu/wiki/STM32MP1_Distribution_Package
After installing some packages here, I went back to the "menuconfig-how to configure kernel" link, and here I got stuck on the following step:
I have the specified files but I don't know in which directory I should run the make config or make menuconfig commands.
To be honest, I am new to embedded Linux and my main goal is to take images with the camera and save this image. However, while trying to do this, I got lost in the documents. Can you help with a road map and what I should do?
2024-06-24 2:06 AM
Hello @alpka ,
I advice you to begin with this wiki article : https://wiki.st.com/stm32mpu/wiki/STM32MP1_Developer_Package
It will give you the basics first.
Then take some time to understand how to modify the Linux configuration / Linux code, recompile it and deploy it on the target. It will help you to go forwards with the mandatory tools to begin playing with the board.
Kind regards,
Erwan.
2024-06-24 2:06 AM
Hello @alpka ,
Kind regards,
Erwan.
