X-CUBE-MATTER and CMake
vohorci
I want to use CLion for development, which requires CMake, and I've been struggling with integrating the X-CUBE-MATTER package in it.
Globbing all files with
file(GLOB_RECURSE src_files "Middlewares/*.c" "Middlewares/*.cpp" "Drivers/*.c" "Drivers/*.cpp")
produces a binary significantly larger than FLASH and still fails to compile because it includes various examples and templates.
Another option I thought of is manually adding all the necessary files, however that seems like a herculean task.
Is there an easier way to go on about this (perhaps ST is already working on it)?
Thank you for your reply.
0 REPLIES 0
