2022-09-15 5:05 AM
I try to create a GATT server with a NUCLEO-WB15CC.
I'm a beginner with STM32WB MCUs so I followed the Getting Started Series video and particulary : "STM32WB Getting Started Series: Part 12b, Lab. Receiving data from the phone"
When its came time to test the firmware my device was not detected in ST BLE ToolBox mobile App
I tried to upgrade the BLE stack Firmware with "stm32wb5x_BLE_Stack_full_fw.bin" but nothing changed.
Then I tried the example Firmware BLE_p2pServer and it's work.
It's seems to be a problem links to STM32WB15. Indeed in the video they used a STM32WB55 and in the comment of the video other persons has the same problem when using a STM32WB15.
Does anybody had this problem and knows how to fix it?
Thank you
2023-10-08 6:31 AM
okay i solved it by upgrading the FUS according to STM32WB Getting Started Series: Part 9, STM32WB FUS update
2025-07-29 6:12 AM
HI @Remy ISSALYS ,
Are the values you have mentioned before constants..? Can I change them in order to increase the no. of services and characteristics ?
Everytime I change these values, I end up in here
if (status != SHCI_Success)
APP_DBG_MSG(" Fail : SHCI_C2_BLE_Init command, result: 0x%02x\n\r", status);
/* if you are here, maybe CPU2 doesn't contain STM32WB_Copro_Wireless_Binaries, see Release_Notes.html */
Error_Handler();
Let me know what could be the possible reason..?
