Why no Bluetooth signal and phone cannot connect to STM32WB10
Teo
There are some parts of the schematic and board view. I was created my own test project from video on YouTube from st.com. Also was tested stm32wb15 example projects with heart rate monitor which are worked.
UPD: APPE_SysUserEvtRx is called
IPCC_C1_TX_IRQHandler is called
IPCC_C1_RX_IRQHandler is called
Also, my option bytes on screenshot
WIRELESS_FW_RUNNING іn stock
SHCI_C2_BLE_Init cause Error Handler with 0x01 code
Teo
UPD2: Solved.
Set correct option bytes for BOOT.
After CFG_HW_RESET_BY_FW set Disabled
7 REPLIES 7
Teo
UPD2: Solved.
Shahin
As I correct in saying you flashed the WB15 example on the WB10 and it worked?
I just created my own custom WB10 board but unfortunately there are not any examples to test so curious if this works and if you had to change anything?
Teo
Oh. Same with me) Trying to create own device with this BLE is mind-blowing. Sure it works if you flashed wb15 example.
@Community member​ I have managed to get the custom template working from scratch on the WB10, basic mycharwrite and mycharnotify so far! but it's progress!
Teo
@Shahin​ ​ sure, i thinks same, but now i dealing with error 133 and some magic... :sad_but_relieved_face:
Teo
