Using STM32WB55 Based on 32 KHz LSE how can we generate 40 KHz signal.
‎2023-03-15 4:09 PM
Dear all,
How can we generate a 40 KHz signal based on LSE (32KHz crystal)?
If I Feed the HSE 32MHz / 32 to run the either LPTIMER's would it be still in low power?
Thanks,
mmsya.
- Labels:
STM32WB series
‎2023-03-17 2:43 AM
Hello @Community member​ ,
- Enable the LSE crystal as the clock source for the RTC (Real-Time Clock) peripheral.
- Enable the LPTIM peripheral and configure it to run in PWM mode.
- Set the LPTIM's prescaler and ARR (Auto Reload Register) values to generate a 40 kHz PWM signal.
- Configure the LPTIM's compare register to generate the desired duty cycle for the PWM signal.
- Enable the PWM output on the LPTIM's corresponding GPIO pin
Foued
‎2023-03-17 2:43 AM
Foued
