STM32WL End Node RTC BCD Calendar Mode
MLour.1
I'd like to know if it's possible to use RTC with a BCD Calendar mode with the end node example. Indeed, I've tried to, but it seems that the timer server doesn't work when i'm not using the binary mode.
Thanks !
Nikosant03
Hi did you figure out how to operate calendar mode? I tried with the end node example but the time won't update
