[STM32WB55] How to change the operation cycle of each server and scanner in iBeacon
Nemonas
  • I want to shorten the transmission interval between iBeacon server and scanner
Remy ISSALYS
You can look BLE_Beacon example available in STM32CubeWB. To reduce the time between each beacon transmission, you can change the value of the following define:
#define ADVERTISING_INTERVAL_IN_MS  (1000)
Best Regards
1 REPLY 1
Remy ISSALYS
Best Regards
