2020-10-19 07:06 AM
One of our product is equiped with an early stage STM32WB55 version called 'cut 2.0'.
I would like to update the copro wirless binary version to either stm32wb5x_BLE_Stack_full_fw or stm32wb5x_BLE_Stack_light_fw recent version like v1.8.0.
Do you know if v1.8.0 is compatible with 'cut 2.0' and if not what is the most recent version I could update with?
Thanks a lot.
2020-10-19 07:44 AM
Cut2.0 is not expected to be used for any production. Only cut2.1 is.
Hence none of the recent firmware releases are tested on cut 2.0. Moreover this cut 2.0 version is a non secure version.
2020-10-19 08:19 AM
Well, we've bought hundreds of thousands of those 'cut 2.0' last year... so it is weird that it was not usable for production.
Moreover if I check the the bluetooth listing of SMT32WBxx it says hat hardware version availability is 'v2.x' so 2.0 is qualified as well as 2.1 for all software version v1.x:
2020-10-19 08:36 AM
Weird indeed!!
Let me check this point with the sales and marketing team.
2020-10-19 08:37 AM
Thanks a lot!
2020-10-20 01:01 AM
Could you fill your profile with the name of the company you are working for?
2020-10-20 02:26 AM
Hi Rémi,
If you don't mind I would rather continue this talking in a more private way.
It seems we've an assigned sales contact, so I would rather pass through him to be redirected at the end to the support team (maybe you actually).
Thank you for your kind support.
2020-10-20 02:42 AM
If you are looking for privacy, It's the best way for sure.
