STM32WB55 BLE
2025-02-19 7:03 PM - last edited on 2025-02-20 2:38 AM by Peter BENSCH
Edit by ST Moderator: This post has been translated from Chinese to comply with the ST Community Terms and Conditions (§10.2).
When I burned the Bluetooth protocol stack onto the new chip, my code was not executed efficiently and the Bluetooth broadcast was not enabled. I checked the documentation and found that the protocol stack needs to be started, but the corresponding buttons in my STM32Programmer are greyed out. I would like to know how to solve this problem.
当我将蓝牙协议栈烧录到新芯片上时,我的代码没有得到有效执行,蓝牙广播也没有启用。我查看了文档,发现协议栈需要启动,但是我的 STM32Programmer 中相应的按钮是灰色的。我想知道如何解决这个问题。
- Labels:
STM32WB series
2025-02-19 9:36 PM
Hello @CHEN25
Could you please try to update the stack using the last version.available on the STM32CubeWB V1.21.0 and using the last version of the STM32CubeProgrammer 2.18.0.
Best Regards.
STTwo-32
2025-02-19 9:36 PM
Hello @CHEN25
Best Regards.
STTwo-32
2025-02-20 12:17 AM
Thanks! ,After updating to STM32CubeProgrammer 2.18.0, it works.
