2022-10-26 01:54 AM
I use my own board (as ble server) to notify the client, each notification is 120 bytes, I found that I can only transmit 30 per second. Actually my requirement is 100 transfers per second.
Do I need to modify anything?
2022-10-27 03:28 AM
2022-10-27 03:43 AM
The point is that no one is there to solve the problem, so I have to ask this question a lot.
2022-10-27 04:18 AM
You are there to solve the problem :D
I really think you could use some reading before spamming the forum, just give it a go.
Maybe also put the time to guess if someone else had your same problem in the forum before, or to just put more than 20 seconds before badly formulating your questions and throwing them out there.
You will end up answering all your previous qestions before anyone else.
2022-10-27 06:57 AM
Sorry😂 , but I have searched a lot in many forums, but I really can't find any information about this question. I'm almost there, can I ask you this question?
