2024-01-29 02:20 AM
STM32CubeWL = "STM32Cube MCU Package for STM32WL series", currently version 1.3.0.
Is there a new release planned?
Background: We are using version 1.3.0. We have issues with an application based on LoRaWAN_End_Node_FreeRTOS. We suspect the FreeRTOS integration is causing errors. Maybe a rework / update would help. See Application based on LoRaWAN_End_Node_FreeRTOS hangs sporadically
We also have an eye on the STM32WL5M module, but we need to be sure the firmware using FreeRTOS runs stable.
Thanks!
2024-01-31 03:36 AM
Hello @JBive.1
For the STM32CubeWL, we are not planning for any release on the coming days. If you have a problem that may be related to the package, you can contact our online support team using this link.
Best Regards.
STTwo-32
2024-01-31 03:36 AM
Hello @JBive.1
Best Regards.
STTwo-32
