STM32CubeMonitor-RF for testing BLUENRG-M2SP
‎2023-10-27 3:17 AM
I want to use the BLUENRG-M2SP for an application and I want to test this BLE module before designing a HW. For this, I have a NUCLEO F411RE and a NUCLEO BNRG2A1.
I wonder if it's possible to use STM32CubeMonitor-RF as a serial terminal in order to send ACI commands from a computer to the BNRG2A1 thorugh the USB dongle provided with the P-NUCLEO-WB55.
Thanks in advanced,
David
BLE
STM32WB series
STM32WBA series
‎2023-11-13 7:34 AM
No, cubeMonitorRF tool cannot be used.
You should use the BlueNRG GUI PC tool (STSW-BNRGUI - BLUENRG family GUI - STMicroelectronics) that will do the same.
It is normally intended to be used with Nucleo-L476RG flashed with Virtual COM port available in X-CUBE-BLE2 package.
You then should port this application for your NUCLEO F411RE, then you 'll be able to use the GUI for sending ACI command from the PC.
Laurent
‎2023-11-13 7:34 AM
Laurent
