STM32CubeIDE debug with ST-Link V2
‎2024-07-18 9:14 AM
Dear All,
let me ask for your kind support.
I am able to debug a customized board equipped with STM32WLE micro by using the STM32CubeIDE program (Version: 1.3.0.20) with the connection to a ST-LINK V2 device.
On a second PC I installed the STM32CubeIDE program version1.15.1, I am able to build a running program on the same customized board. I did also the Debug Configurations
(the same parameters of the version 1.3.0.20) but I am not able to debug.
After the compilation I get this final message on the console
STMicroelectronics ST-LINK GDB server. Version 7.7.0
Copyright (c) 2024, STMicroelectronics. All rights reserved.
Starting server with the following options:
Persistent Mode : Disabled
Logging Level : 1
Listen Port Number : 61234
Status Refresh Delay : 15s
Verbose Mode : Disabled
SWD Debug : Enabled
Target no device found
Error in initializing ST-LINK device.
Reason: No device found on target.
Some seconds later a box appears with this further message
Error in final launch sequence:
Failed to execute MI command:
target remote localhost:61234
Error message from debugger back end:
localhost:61234: Connection timed out.
Could you kondly give me a piece of advice?
Best Regards,
Mario Sandri
‎2024-07-25 8:01 AM - edited ‎2024-07-25 8:02 AM
Hi Ascha.3,
thank you for your quick reply and suggestion.
Now my board debug works with interface SWD, Frequency (kHz): Auto, Connect under reset.
I connected only to my STM CPU, I do not have other CPU boards.
Best Regards,
Mario
‎2024-07-18 9:46 AM
how you set the -connect- ?
Try:
Can you connect to any other STM cpu ? (on other matching project, of course )
Hi Ascha.3,
Best Regards,
Mario
‎2024-08-15 9:09 PM
Hi all,
This is my first project i have been working on,i installed stm32cube ide for first time.
board:STM32H563ZIT6
I am have some error while debugging.I want to debug the software.I don't have hardware.How do i debug it.
when iam trying to do,it is showing me error like this:
target remote 127.0.0.1:8500
127.0.0.1:8500: Connection timed out.
My debugger settings are like this:
Please give me solution for this error
