Setting up TouchSensing library
‎2024-08-14 10:08 PM
Hi there, I'm currently trying to setup the STM32_Touchsensing library.
I have already downloaded the library from
ST(https://github.com/STMicroelectronics/STM32CubeWB/blob/master/README.md#how-to-use).
How do I enable this Touch sensing library now that I have downloaded it
Thanks!
STM32Cube MCU Packages
‎2024-08-15 12:42 PM
After checking, your MCU does not support the touch sensing capability.
You need to use another one.
Best Regards.
STTwo-32
‎2024-08-14 11:09 PM
Hello @Parry
So, the STM32_Touchsensingis a middleware that can be used with some STM32 MCUs. So, all you have is to open CubeMX, select an MCU or a board that you are going to use (as i can see is an STM32WB) and start your project. On the configuration panel of CubeMX m, go to middleware and enable the STM32_Touchsensing (you lay also have some settings to do for the middleware parameters).
Best Regards.
STTwo-32
‎2024-08-15 11:01 AM
Hi there, I do not see an option to enable touch sensing for this MCU. It does appear to automatically be there for the
STM32F072RB MCU though.
Is there something I need to configure in order to get it to appear?
‎2024-08-15 11:27 AM
It should be under middleware. It may be garyed. If so, please put you cursor on it and a message that tell you what you have to do before you can enable it.
Dont forget to use the last version of CubeMX (V6.12.0).
Best Regards.
STTwo-32
‎2024-08-15 12:02 PM
I cannot seem to find a grayed on TSL library
‎2024-08-15 12:37 PM
never mind, the STM32WB55CE does not have touch sensing capabilities.
Best Regards.
STTwo-32
