2018-08-27 6:19 AM
Hello ,
I use this demo board B-L072Z-LRWAN1 with the soft End Node I-CUBE-LRWAN 1.2.0
But I do not understand why I cant send the message
i disable all senser and i try to send with
" LORA_send( &AppData, LORAWAN_DEFAULT_CONFIRM_MSG_STATE); "
in static void Send( void )
Thank you.
2018-09-11 10:52 PM
did you check all the keys and proper registration of the node in the TTN-Console?
2018-12-20 9:26 PM
You can also refers the logs of your gateway.
