PCB Antenna Design for STM32WL55 at EU868 – Guidance Needed
2025-02-27 2:14 AM
Hello STM Community,
I am designing an internal PCB antenna for LoRa communication using the STM32WL55JCI7 at EU868 frequency. Is a PCB antenna recommended by STM for this chip? If so, what guidelines or procedures should I follow for designing a PCB antenna for LoRa communication? Additionally, what range can I expect with an optimized PCB antenna design?
Looking forward to your insights. Thanks!
STM32WL series
2025-03-25 5:01 AM
Hello @Nikunj_17
There is not a particular design guide dedicated for antenna. But I may recommend you the:
You can also refer to the antenna of the MB1389.
Best Regards.
STTwo-32
2025-03-25 8:21 PM
Thank you so much for your recommendation! Do you also have any reference board for a PCB antenna designed for LoRa communication at EU868?
2025-03-26 2:05 AM - edited 2025-03-26 2:05 AM
Such a design does not exist, but you can refer to the antenna design of the MB1389 that I've mentioned on my first comment.
Best Regards.
STTwo-32
