NUCLEO-WL55JC reset when laptop attached to it.
  • November 13, 2024
  • 10 replies
  • 3140 views
I use the NUCLEO-WL55JC STM32WL Nucleo-64 board, which I supply with an external power supply.
Each time I attach my laptop in order to view the console, the WL55JC is reset. I assume the STLINK-V3E issues a reset to the WL55JC.
Is there a possibility to avoid that?
I tried to take away the jumper that allows T_NRST to be connected to ST-LINK, but then, when I attach my laptop the board, the WL55JC enters an unusual state (it neither continues normal operation nor does a reset). Except for this I did not find any other ideas how to change the behavior. Is there any?
Best answer by HOPilsan
First I left SWDIO and SWCLK, then I removed them. No change.
Yep, a good idea o check the voltages. I'll do that.
Andrew Neil
What "console" are you using?
HOPilsanAuthor
It is LPUART1 which is tunneled by the ST_LINK through USB to my laptop.
Andrew Neil
Does the board have jumpers/solder-bridges to disconnect the NRST from the ST-Link to the target?
Or use a separate USB-to-UART adaptor.
Sco
You mentioned you " take away the jumper that allows T_NRST to be connected to ST-LINK", would you confirm which jumper you removed?
BTW, if you assume it's impacted by the NRST, another way is to monitor this signal to see if there is a drop when the reset happens.
HOPilsanAuthor
It was jumper JP8 position 9-10. I'll check both NRST and the voltages and give feedback.
Andrew Neil
