NUCLEO-WL55J STM32WL Flash Erasing failed after loading the BFU_LoRaWAN_End_Node.bin Please share your inputs to disable the flash write protection.
HVeer.1
I have used STM32Cube_FW_WL_V1.1.0 -> LoRaWAN_FUOTA -> 1_Image sample and build the binary file ->  BFU_LoRaWAN_End_Node.bin
After flashing the binary, STM32WL66 Option Bytes got changed and i could not able to erase and update the fflash after that. i tried with mass erase, but it did not help. Please share your inputs to disable the flash write protection.
c:\Program Files\STMicroelectronics\STM32Cube\STM32CubeProgrammer\bin>STM32_Programmer_CLI.exe -c port=swd -ob displ
            STM32CubeProgrammer v2.7.0
ST-LINK SN : 001600345553500B20393256
ST-LINK FW : V3J7M3
Board    : NUCLEO-WL55JC
Voltage   : 3.26V
SWD freq  : 12000 KHz
Connect mode: Normal
Reset mode : Software reset
Device ID  : 0x497
Revision ID : Rev Z
Device name : STM32WLxx
Flash size : 256 KBytes
Device type : MCU
Device CPU : Cortex-M4
UPLOADING OPTION BYTES DATA ...
 Bank     : 0x00
 Address    : 0x58004020
██████████████████████████████████████████████████ 100%
 Bank     : 0x01
 Address    : 0x58004080
OPTION BYTES BANK: 0
  Read Out Protection:
   RDP     : 0xAA (Level 0, no protection)
  BOR Level:
   BOR_LEV   : 0x0 (BOR Level 0 reset level threshold is around 1.7 V)
  User Configuration:
   nBOOT0    : 0x1 (nBOOT0=1)
   nBOOT1    : 0x1 ()
   nSWBOOT0   : 0x1 (BOOT0 taken from PH3/BOOT0 pin)
   SRAM_RST   : 0x1 (SRAM1 and SRAM2 are not erased when a system reset occurs)
   SRAM2_PE   : 0x1 (SRAM2 parity check disable)
   nRST_STOP  : 0x1 (No reset generated when entering the Stop mode)
   nRST_STDBY  : 0x1 (No reset generated when entering the Standby mode)
   nRST_SHDW  : 0x1 (No reset generated when entering the Shutdown mode)
   WWDG_SW   : 0x1 (Software window watchdog)
   IWGD_STDBY  : 0x1 (Independent watchdog counter running in Standby mode)
   IWDG_STOP  : 0x1 (Independent watchdog counter running in Stop mode)
   IWDG_SW   : 0x1 (Software independent watchdog)
   BOOT_LOCK  : 0x1 (CPU1 CM4 Boot lock enabled)
   C2BOOT_LOCK : 0x1 (CPU2 CM0+ Boot lock enabled)
   IPCCDBA   : 0x3FFF (0x3FFF)
  Security Configuration Option bytes ESE:
   ESE     : 0x1 (Security enabled)
  PCROP Protection:
   PCROP1A_STRT : 0xFF (0x803FC00)
   PCROP1A_END : 0x0 (0x8000000)
   PCROP_RDP  : 0x1 (PCROP zone is erased when RDP is decreased)
   PCROP1B_STRT : 0xFF (0x803FC00)
   PCROP1B_END : 0x0 (0x8000000)
  Write Protection:
   WRP1A_STRT  : 0x58 (0x802C000)
   WRP1A_END  : 0x7D (0x803E800)
   WRP1B_STRT  : 0x0 (0x8000000)
   WRP1B_END  : 0xA (0x8005000)
OPTION BYTES BANK: 1
  Security Configuration Option bytes:
   SFSA     : 0x38 (0x38)
   FSD     : 0x0 (System and Flash secure. This bit can only be accessed when HDPADIS = 0)
   DDS     : 0x1 (CPU2 debug access disabled (when also enabled by C2SWDBGEN))
   HDPSA    : 0x7D (0x7D)
   HDPAD    : 0x0 (User Flash hide protection area access enabled.)
   SUBGHSPISD  : 0x1 (FSD=0 and SUBGHSPISD=1: SPI3 security disabled)
   C2OPT    : 0x1 (SBRV will address Flash memory, from start address 0x0800 0000 + SBRV.)
   NBRSD    : 0x1 (SRAM1 is non-secure if FSD=0 and secure otherwise. This bit can only be accessed when HDPADIS = 0)
   SNBRSA    : 0x1F (0x1F)
   BRSD     : 0x0 (SRAM2 is secure if FSD=0 and non-secure otherwise. This bit can only be accessed when HDPADIS = 0)
   SBRSA    : 0x0 (0x0)
   SBRV     : 0xDA00 (0xDA00)
3 REPLIES 3
YBOUV.1
Senior
Hi @HVeer.1​ ,
can you please try this?
disable_security.bat
please, let us know
HVeer.1
I tried using disabled security.bat, please find herewith the output and share your inputs
YBOUV.1
Senior
Hi @HVeer.1​ ,
ESE is active. As long as it is, we can not modify configuration of WRP.
You have to set back to RDP level 1, then regress to RDP level 0 and remove ESE.
Then you will be able to remove WRP protection.
In UM2767 : 8.6 Programming a new software when the securities are activated
best regards
