MemManage fault detected in instruction located at 0x6414AA00.
‎2022-10-13 2:27 PM
I'm developing a custom board with STM32WB55.
Because there is some error during debugging, I'm trying to solve it.
To check what is problem in the microcontroller, I tried Fault Analyzer in the STM32CubeProgrammer and the program found such an error below.
"MemManage fault detected in instruction located at 0x6414AA00"
Here is the question.
How can I understand what's this error and how can I fix it?
STM32CubeProgrammer
STM32WB series
‎2022-11-07 6:57 AM
According to UM2237 documentation the Memory Management Fault detects memory access violations to regions defined in the memory management unit (MPU), such as code execution from a memory region with read/write access only. If this fault was triggered by a faulty address, access is displayed on the MMFAR text field.
For the second point DIV_0_TRP allow to enable Usage Fault when the processor executes an SDIV or UDIV instruction with a 0 divider:
- 0 = do not trap divide by 0; a divide by 0 returns a quotient of 0.
- 1 = trap divide by 0.
Best Regards
‎2022-10-13 2:30 PM
I can see this error also.DIV_0_TRP bit was enabled.
What is this? and How can I understand this error and fix it?
‎2022-11-07 6:57 AM
Best Regards
‎2022-11-10 4:03 AM
Thanks for your reply...this problem is solved.
