2024-09-17 8:19 AM
Anybody from ST or Users done any development or research on the "new" relay node on the STM32WL.
Will the stack be updated or will we have to do this on our own?
Stefan
2024-09-18 1:47 AM
Hello @tech2399
The LoraWAN Relay, we Plan to integrate it on the coming releases of the STM32CubeWL. But for now, you may need to do the implementation since is not yet supported on the current stack.
Best Regards.
STTwo-32
2024-09-17 8:26 AM
Hello @tech2399
Are you talking about an update of the Firmware on the Board. That is available throw the FUOTA (look at the AN5554). For the SDK STM32CubeWL, it will be an update from the version 1.3.0 on the coming days but i can't communicate a date now.
Best Regards.
STTwo-32
2024-09-18 12:39 AM - edited 2024-09-18 12:41 AM
No, I'm talking about a new feature with Lora where an end node can perform a relay function :
2024-09-18 1:47 AM
Hello @tech2399
Best Regards.
STTwo-32
2024-09-18 3:33 AM
Thank you
2025-03-07 1:01 PM
Do you have an approximate timeframe for when the release of CubeWL with relay will be released?
