2019-06-20 03:29 AM
Attaching the log files.
Open On-Chip Debugger 0.10.0+dev-00021-g524e8c8 (2019-04-23-20:37)
Licensed under GNU GPL v2
For bug reports, read
http://openocd.org/doc/doxygen/bugs.html
srst_only separate srst_nogate srst_open_drain connect_assert_srst
Info : The selected transport took over low-level target control. The results might differ compared to plain JTAG/SWD
adapter speed: 8000 kHz
adapter_nsrst_delay: 100
Info : Listening on port 6666 for tcl connections
Info : Listening on port 4444 for telnet connections
Info : clock speed 8000 kHz
Info : STLINK v2.1 JTAG v31 API v2 M21 VID 0x0483 PID 0x374B
Info : using stlink api v2
Info : Target voltage: 3.253438
Info : Unable to match requested speed 8000 kHz, using 4000 kHz
Info : Stlink adapter speed set to 4000 kHz
Info : STM32L072CZYx.cpu: hardware has 4 breakpoints, 2 watchpoints
Info : Listening on port 3333 for gdb connections
Info : accepting 'gdb' connection on tcp/3333
target halted due to debug-request, current mode: Thread
xPSR: 0xf1000000 pc: 0x080021dc msp: 0x20005000
STM32L0: Enabling HSI16
adapter speed: 4000 kHz
Info : Device: STM32L0xx (Cat.5)
Info : STM32L flash has dual banks. Bank (0) size is 96kb, base address is 0x8000000
Info : STM32L flash has dual banks. Bank (1) size is 96kb, base address is 0x8018000
Info : Padding image section 0 with 4 bytes
target halted due to breakpoint, current mode: Thread
xPSR: 0x61000000 pc: 0x2000000e msp: 0x20005000
Warn : keep_alive() was not invoked in the 1000ms timelimit. GDB alive packet not sent! (3269). Workaround: increase "set remotetimeout" in GDB
Error: jtag status contains invalid mode value - communication failure
Warn : target STM32L072CZYx.cpu is not halted (gdb fileio)
Polling target STM32L072CZYx.cpu failed, trying to reexamine
Examination failed, GDB will be halted. Polling again in 100ms
Info : Previous state query failed, trying to reconnect
Examination failed, GDB will be halted. Polling again in 300ms
Examination failed, GDB will be halted. Polling again in 700ms
Examination failed, GDB will be halted. Polling again in 1500ms
Examination failed, GDB will be halted. Polling again in 3100ms
Warn : WARNING! The target is already running. All changes GDB did to registers will be discarded! Waiting for target to halt.
Examination failed, GDB will be halted. Polling again in 6300ms
2019-06-20 05:06 AM
General things which will give problems are overly high speeds on the SWD port, and the device going into low power modes.
When debugging it is generally advisable to define LOW_POWER_DISABLE
Consider also use of tools like Keil, which has a free license for ST Micro CM0(+) devices, which would include the L0
2019-06-20 05:06 AM
2019-06-20 05:27 AM
Fixed.. As you said disabling low power mode was the key.. Since this option was available in many places, was unable to get it done. Changing it in the hw_conf.h finally fixed it
