2019-09-25 12:56 AM
Everything seems to work fine in putty except the join, but the signal is not received by TTN, while it is received when i use v1.1.2 (https://github.com/drakkar-lig/st-lrwan). I changed the devEUI, appEUI and appKey.
2019-09-25 03:55 PM
Did you make sure you are using the right frequency?
