I am developing a design with a STM32WLE5JCI6TR MCU. Regarding the pin PB0-VDDTCXO, if I am not using a TCXO in my design, should I simply connect this pin to groud?
AZube.2
YBOUV.1
you can simply use it as any GPIO (PB0)
That would depend on if other code sets the pin high, assuming that will power a TCXO, then you're basically shorting that to ground, pulling maximal current through the transistor. Doesn't seem like a good plan to me.
YBOUV.1
AZube.2
Okay! Thanks both for the reply.
