How to use STSAFE-A110 for LoRaWAN ?
I'm trying to use the STSAFE-A110 to store my LoRaWAN keys, to generate session keys and to encrypt my payloads through it.
I'm supposed to send commands to the secure-element but for the symetric encryption, neither the datasheet nor the source code gives us the command to send.
Furthermore, I read that it exists 16 slots for symetric encryption (into the STSAFE-A110 datasheet §3.3). How can I access it ?
Is-it only possible to do that with infos under NDA ?
Thank you !
