How to update STM32WB55CE FUS and wireless stack ?
2021-06-16 01:26 AM
Having issues with STM32WB55CE FUS and wireless stack update. FUS version:
Reading 32-bit memory content
Address: : 0x20010010
0x20010010 : 01010100
FUS upgrade >STM32_Programmer_CLI.exe -c port=swd mode=UR -fwupgrade stm32wb5x_FUS_fw.bin 0x0807A000 firstinstall=0, getting:
Error: Could not execute fwupgrade command, Impossible to install FUS V1.0.1 on
256/512KB Flash Parts
Wireless stack update >STM32_Programmer_CLI.exe -c port=swd mode=UR -fwupgrade STM32WB55\stm32wb5x_BLE_Stack_full_fw.bin 0x08056000 firstinstall=0
STM32CubeProgrammer v2.7.0
ST-LINK SN : 52FF74067575555041500481
ST-LINK FW : V2J37S7
Board : --
Voltage : 3.26V
SWD freq : 4000 KHz
Connect mode: Under Reset
Reset mode : Hardware reset
Device ID : 0x495
Revision ID : Rev Y
Device name : STM32WB5x
Flash size : 512 KBytes
Device type : MCU
Device CPU : Cortex-M4
Old wireless stack delete ...
Warning: Option Byte: nSWboot0, value: 0x0, was not modified.
Warning: Option Byte: nboot0, value: 0x1, was not modified.
Warning: Option Byte: nboot1, value: 0x1, was not modified.
Warning: Option Bytes are unchanged, Data won't be downloaded
Succeeded to set nSWboot0=0 nboot1=1 nboot0=1
Memory Programming ...
Opening and parsing file: 0x495_FUS_Operator.bin
File : 0x495_FUS_Operator.bin
Address : 0x08000000
Erasing internal memory sectors [0 1]
Download in Progress:
██████████████████████████████████████████████████ 100%
File download complete
Time elapsed during download operation: 00:00:00.765
Application is running, Please Hold on...
Reconnecting...
Reconnected !
Warning: FUS_STATE_IMG_NOT_FOUND, Flash already empty !
Firmware delete Success
Download firmware image at address 0x8056000 ...
Opening and parsing file: stm32wb5x_BLE_Stack_full_fw.bin
File : stm32wb5x_BLE_Stack_full_fw.bin
Address : 0x08056000
Erasing internal memory sectors [86 127]
Time elapsed during download operation: 00:00:04.664
Firmware Upgrade process started ...
Reconnecting...
Reconnected !
Error: The FUS version you're trying to install is older/equal to the FUS versio
n already installed !
Error: fwupgrade Command Failure!
Firwmware upgrade failed! Deleting firmware and exiting...
failed to erase memory
Failed to download FUS operator!
Could not start firmware upgrade service, old firmware delete failed
Any suggestions to fix this issue ?
STM32CubeProgrammer
STM32WB series
2021-06-16 01:42 AM
What STM32WB firmware package do you use ?
In STM32WB firmware package V1.11.1, FUS version should be v1.2.0 not V1.0.1
2021-06-16 02:27 AM
With stm32wb5x_FUS_fw.bin from STM32CubeWB v1.11.0, was able to update the FUS to V1.1.2.0, still unable to upload the wireless stack:
>STM32_Programmer_CLI.exe -c port=swd mode=UR -fwupgrade stm32wb5x_BLE_Stack_full_fw.bin 0x08056000 firstinstall=0
Error: The FUS version you're trying to install is older/equal to the FUS version already installed !
2021-06-16 02:41 AM
I don't know more.
Maybe @Remi QUINTIN can help ?
2021-06-16 07:29 AM
There was an issue with CubeProgrammer 2.7 with 256K WB variant.
Could you revert to CubeProgrammer v2.6 and try again?
I dont think it is a FUS issue.
Could you tell me the FUS version on your board? It looks like being v1.1.1 but you can read it using CubeProgrammer en USB DFU mode.
2021-06-16 07:37 AM
@Remi QUINTIN
V1.1.2.0
he wrote that earlier:
2021-06-16 07:50 AM
Strange as the FUS version available in the V1.11 package is the FUS v1.2.0.
2021-06-16 07:58 AM
I don't think so, from WB packages release notes:
V1.11.0 contains FUS 1.1.2 - 02/05/2021
V1.11.1 contains FUS 1.2.0 - 04/06/2021
2021-06-16 08:47 AM
CubeProgrammer v2.6 does not recognize the current FUS version. It showed:
0x20030030 : 00000000
An attempt to update the FUS/wireless stack produced the following error:
Firwmware upgrade failed! Deleting firmware and exiting…
2021-06-16 08:47 AM
Indeed you are right. I am using v1.11.1
Back to the original issue, I know there is an issue with CubeProgrammer v2.7 with 256KB WB variant.
It should be solved in the next release V2.8 expected in a few weeks (less than a month).
