How to remove past Low Power Node(LPN) assigned address without system reset in Mesh Network?
Deepak.Aagri
Hello ST,
During the provisioning in mesh network a node address assigned by PROVISIONER. which is going to be stored in LPN node memory.
-----------------Debug Trace-----------
BLEMesh_PbAdvLinkOpenCb - PB-ADV Link opened successfully
BLEMesh_PvnrDataInputCallback - Device Key: d4 ac c7 95 da 3c 8a 1d b7 dc d6 a0 50 3f fa a9
BLEMesh_PvnrDataInputCallback - App Key: e3 c5 54 9d d1 19 bf 00 56 80 9a 54 6a 54 e1 04
BLEMesh_PvnrDataInputCallback - Node Address Assigned = 3
Device is provisioned by provisioner
i want to delete this "Node Address Assigned = 3" from the LPN memory without system reset. so i can reuse this number again from provisioner side.
Best Regards
Deepak Aagri
Remy ISSALYS
The only way to delete the  "Node Address Assigned = 3" is to unprovisione the provisioner node and provision again the network.
Best Regards
Remy ISSALYS
Best Regards
