How to fix "Old firmware delete failed" error while trying to firmware update?
‎2021-08-19 2:10 AM
I tried to update the firmware on P-NUCLEO-WB55 devboard, but it fails with the following error:
"Error: FUS_STATE_ERR_UNKNOWN
Error:
Old Firmware delete failed"
I check in STM32CubeProgrammer, and I have V.0.0.0 version:
I do not know why it happened, maybe a previous incorrect way of upgrade process.
Any idea how can I resolve it?
Additional info:
The dongle is ok, I could update it via USB, it has fw V1.1.2.0 version.
- Labels:
STM32WB series
‎2021-08-19 4:28 AM
Nothing strange regarding the option bytes.
Can you launch a FW delete command?
‎2021-08-19 4:31 AM
No, because as I wrote earlier, the error message is:
Error:
via ST-LINK. Via USB only the dongle I can see, and the command is working. At that point I'm little bit uncertain because I did not see any info regarding the need for dongle upgrade.
‎2021-08-19 4:32 AM
It looks like the old firmware is damaged and cannot be recognized. One solution would be to directly flash the memory with the fw file. Ignoring the old firmware error issue.
‎2021-08-19 4:40 AM
But The SFSA = 0xD0 which means there is a FW already and still installed on the board!!!
It is not deleted.
I assume that your board configured in USB DFU mode (with a jumper set on CN7 position (67 + the USB USER connector) is not discovered by CubeProgrammer because nSWBOOT0 = 0 while it should be set to 1 for the USB DFU mode.
‎2021-08-19 4:46 AM
I am afraid you won’t be able to flash a recent version of the FW with an old version of FUS.
I am quite puzzled by your issue.
Could you try with CubeProgrammer version 2.8?
‎2021-08-19 4:48 AM
It is not deleted.
--> I assumed it, because I never could delete it. Looks like it is damaged.
--> I tried it now, but the error is after trying to connect:
‎2021-08-19 4:54 AM
I'll do and will give you feedback.
‎2021-08-19 4:57 AM
I want to correct my statement regarding the USB configuration : the jumper must be set on position 5-7 on CN7.
Have a look at the attached document.
‎2021-08-19 5:01 AM
Don't worry, I did the same from the beginnging. :)
‎2021-08-19 5:19 AM
Unfortunately it failed. same result with 2.8 version.
