How to create a web server using stm32wb without connecting to a wifi router
NSali.1
if it was impossible I would be glad to explain
Amogh
were you able to find an answer to your question?
LCE
Principal
I don't know what stm32wb is, so I'm not sure if I had a similar problem, when I wanted to connect my Nucleo-board via ethernet directly to my laptop, but the nucleo's ethernet was setup to use DHCP.
I had to use another software tool to make my laptop the DHCP server.
Just found it, I used "dhcpsrv2.5.2", some freeware from ... somewhere. I had to play a little with that, but then I got it running.
No guarentees though...
