How to create a BLE application step by step using STM32WB55 P-Nucleo
2021-10-08 1:04 PM
I am using the STM32WB55 Nucleo board and have gone through a few of the example applications. I would now like to create my own BLE application similar to the heart rate monitor.
I really am not sure how to start and was hoping for a decent tutorial or video on the flow of adding BLE functionality.
If anyone has any tips I would really appreciate it.
BLE
STM32WB series
2021-10-11 2:33 AM
Hello @kcire L. ,
Have a look at the attached getting started and workshop for BLE.
Also, refer to the following resources :
- AN5289 Application note "Building wireless applications with STM32WB Series microcontrollers".
- Video: STM32WB Getting Started Series: Part 5, CubeWB Heart Rate Monitor to start developing your application.
I hope these resources are helpful for you.
Imen
Imen
2021-10-12 5:26 AM
Thank you for your response. I've watched the video you suggested. I'm also looking at the BLE Heart Rate Monitor example and trying to go through the steps in AN5289.
I cannot find even the first call aci_hal_write_config_data() to configure the BLE device public address. I assume this is used, but I am not sure where this code resides? Again, I am trying to create a BLE application from scratch.
Thank you again
2021-10-21 7:10 AM
Hi @kcire L. ,
The aci_hal_write_config_data command writes a value to a low level configure data structure, and it is useful to set up directly some low level parameters for the system in the runtime.
Please refer to the "4.8.1 Aci_Hal_Write_Config_Data" section in the UM1865, to have more details about the configuration of this command.
Imen
Imen
