2019-01-15 8:47 AM
I have STM32L4A6VGTx with SPWF04SA wifi module on it. I want to send sensor data to Amazon IoT.
I can see AT+S.TLSCERT commands for the wifi module. I have created a thing on Amazon IoT core and I have downloaded certificiates (myrootCA1.pem, mycertificate.pem.crt, myprivate.pem.key.
I am not sure which AT commands should I use to connect with Amazon IoT?
Do I need to copy all certificates in my code?
After Amazon IoT connection, I want to send data using MQTT AT commands ...
Thanks,
Mehul
#amazon #SPWF04SA #iot #mqtt
