How to collect the details of active Low power node in Mesh Network?
Deepak.Aagri
Hello ST,
Once the provisioning process over associate node will Save provisioning data in SubPage[%.8x]\r\n", PRVN_NVM_SUBPAGE_OFFSET(subPageIdx)); using AppliPrvnNvm_Process(); function. Is there any possibility we can we read this memory?
I didn't get any function to know the availability of Low power active node in existing network?
BLEMesh_NeighborRefreshedCallback(); function works only for unprovision node..
Please enlighten me on this issue..
Best Regards
Deepak Aagri
Remy ISSALYS
Unfortunately there is no possibility to read provisioning data saved in provisioner node. Any function is available to know low power active node in existing network.
Best Regards
