2023-06-05 8:19 AM
I am working with the STM32WB15 controller. I have implemented a few custom BLE characteristics and I want to be able to check the value of the characteristics on the server side (not from a read request from a client device). Is there a way to access the current value of a characteristic?
2023-06-29 2:33 PM
Try aci_gatt_read_handle_value
aci_gatt_read_handle_value((CustomContext.CustomMyTestCharHdle + CHARACTERISTIC_VALUE_ATTRIBUTE_OFFSET),
0, /* charValOffset */
SizeMyTestChar, /* wanted length of data */
&ret_len, /* will return the actual length read */
&buffer_len, /* a pointer to the length of buffer */
buffer /* actual buffer */);
I found it in the AN5270 document
