How can BLE server access its own characteristics?
BMcGe.1
I am working with the STM32WB15 controller. I have implemented a few custom BLE characteristics and I want to be able to check the value of the characteristics on the server side (not from a read request from a client device). Is there a way to access the current value of a characteristic?
1 REPLY 1
tianer2820
Try aci_gatt_read_handle_value
aci_gatt_read_handle_value((CustomContext.CustomMyTestCharHdle + CHARACTERISTIC_VALUE_ATTRIBUTE_OFFSET), 0, /* charValOffset */ SizeMyTestChar, /* wanted length of data */ &ret_len, /* will return the actual length read */ &buffer_len, /* a pointer to the length of buffer */ buffer /* actual buffer */);
I found it in the AN5270 document
