Hello, I am following the following tutorial: "STM32WB Getting Started Series: Part 12b, Lab. Receiving data from the phone." But I have a problem because I don't know how to evaluate the value sent by the mobile. I hope you can help me, thanks.
fvela.1
3 REPLIES 3
Remy ISSALYS
You can look the following wiki page which explain how to generate a Bluetooth® Low Energy (BLE) server custom application for STM32WB55RG MCU using STM32CubeMX software:
https://wiki.st.com/stm32mcu/wiki/Connectivity:STM32WB_BLE_STM32CubeMX
Extract of section 7.4 Code modification: User sections part for custom_app.c file which show how to recover the value send by the smartphone and turn on/off the led according to this value:
/* Functions Definition ------------------------------------------------------*/
void Custom_STM_App_Notification(Custom_STM_App_Notification_evt_t *pNotification)
  /* USER CODE BEGIN CUSTOM_STM_App_Notification_1 */
  /* USER CODE END CUSTOM_STM_App_Notification_1 */
  switch(pNotification->Custom_Evt_Opcode)
    /* USER CODE BEGIN CUSTOM_STM_App_Notification_Custom_Evt_Opcode */
    /* USER CODE END CUSTOM_STM_App_Notification_Custom_Evt_Opcode */
  /* My_P2P_Server */
    case CUSTOM_STM_LED_C_READ_EVT:
      /* USER CODE BEGIN CUSTOM_STM_LED_C_READ_EVT */
      /* USER CODE END CUSTOM_STM_LED_C_READ_EVT */
      break;
    case CUSTOM_STM_LED_C_WRITE_NO_RESP_EVT:
      /* USER CODE BEGIN CUSTOM_STM_LED_C_WRITE_NO_RESP_EVT */
      APP_DBG_MSG("\r\n\r** CUSTOM_STM_LED_C_WRITE_NO_RESP_EVT \n");
      APP_DBG_MSG("\r\n\r** Write Data: 0x%02X %02X \n", pNotification->DataTransfered.pPayload[0], pNotification->DataTransfered.pPayload[1]);
      if(pNotification->DataTransfered.pPayload[1] == 0x01)
        HAL_GPIO_WritePin(Blue_Led_GPIO_Port, Blue_Led_Pin, GPIO_PIN_SET);
      if(pNotification->DataTransfered.pPayload[1] == 0x00)
        HAL_GPIO_WritePin(Blue_Led_GPIO_Port, Blue_Led_Pin, GPIO_PIN_RESET);
     /* USER CODE END CUSTOM_STM_LED_C_WRITE_NO_RESP_EVT */
      break;
Best Regards
I'm looking at the page but the characteristics are sent from the mobile, on this page it is not created in the same way as in the tutorial I followed thanks.
Remy ISSALYS
In custom_stm.c file, try the following code according to youtube video:
case ACI_GATT_ATTRIBUTE_MODIFIED_VSEVT_CODE:
  attribute_modified = (aci_gatt_attribute_modified_event_rp0*) blecore_evt->data;
   if (attribute_modified->Attr_Handle == (CustomContext.CustomMycharwriteHdle + CHARACTERISTIC_VALUE_ATTRIBUTE_OFFSET))
     APP_DBG_MSG("C2 WRITE - LENGTH = %d \n", attribute_modified->Attr_Data_Length);
     APP_DBG_MSG("Reception : ");
     for (i = 0; i < attribute_modified->Attr_Data_Length; i++)
        APP_DBG_MSG("Data[%x] = 0x%x ", i, attribute_modified->Attr_Data[i]);
     APP_DBG_MSG(" \r\n");
Best Regards
