Gateway LoRA
‎2024-10-28 6:22 AM
Who should I contact to obtain the firmware of the P-NUCLEO-LRWAN2.
LoRa
‎2024-10-28 6:30 AM
Note that the P-NUCLEO-LRWAN2 in Not Recommended for New Designs - NRND.
Did you look on the 'Tools & Software' tab of the Product Page:
https://www.st.com/en/evaluation-tools/p-nucleo-lrwan2.html#tools-software
The actual Gateway radio module is from RisingHF:
‎2024-10-28 6:30 AM
‎2024-10-28 6:37 AM
Note that the P-NUCLEO-LRWAN2 gateway is not suitable for public deployment:
https://www.thethingsnetwork.org/forum/t/p-nucleo-lrwan2-cant-connect-ttn-server/43067/11
‎2024-10-28 6:38 AM - edited ‎2024-10-28 6:39 AM
Bonjour @LoisCOSTI
I suggest you contact one of our sales agents or create a case here if you are looking for more details take a look at those posts:
- Solved: Where can I find the file "st-nucleo-lora-gw-at-fw... - STMicroelectronics Community
- How do I get the firmware for P-NUCLEO-LRWAN3 gate... - STMicroelectronics Community
Note that this product is not recommended for new design.
Best Regards.
STTwo-32
‎2024-10-29 2:16 AM
ID lrwan2-d64295
EUI 0080E1FFFF014DC3
Network NS_TTS_V3://ttn@000013
Description Experimental Gateway with LRWAN2 Indoors, third floor
Last heard Tue, Oct 29, 2024 10:03 AM CET
Lat, Lon 49.8573984583099, 8.642817735672
Altitude 148m
Show only this gateway's coverage as:
