Disable Logging WPAN WBA5x
‎2025-03-19 11:14 PM - edited ‎2025-03-19 11:17 PM
I upgraded from CubeIDE 1.17 to 1.18 and from WBA 1.5.0 to 1.6.0 and now I get this error the following error. I have logging disabled in WPAN configuration and no IP selected for logs under platform settings tab.
../Core/Inc/app_conf.h:291:2: error: #error "ERROR : you need to indicate an (LP)UART for the Log on CubeMX."
if I comment out this #error line in aoo_conf.h, I get other errors:
../Projects/Common/WPAN/Interfaces/adv_trace_usart_if.c:73:3: error: 'LOG_UART_HANDLER' undeclared (first use in this function)
So there is some code generated which shouldnt be. There was no problem with this previously.
Best regards
STM32CubeIDE
STM32WBA series
‎2025-04-01 12:07 AM
Hello, can anyone help me? Is it possible to use custom output function for BLE logs, like __io_putchar in newlib?
‎2025-04-01 1:49 AM
Hello @cvs_dk
Could you please send you.ioc file.
Best Regards.
STTwo-32
‎2025-04-01 3:23 AM
‎2025-04-03 12:56 AM
Hello @cvs_dk
To solve this issue, you need to set an (LP)UART interface for Serial Link:
Best Regards.
STTwo-32
‎2025-04-03 1:07 AM
Hello, @STTwo-32 and thank you for response.
Yes I know that, but I don't want to (no uarts free). In CubeIDE 1.17 and WBA 1.5.0 It is not needed to set this, but in last version some code regarding logging is generated despite disabled logs in CubeMX.
‎2025-04-03 1:59 AM
I've escalated a request internally (under internal ticket number 206702) to make this setting mandatory only if CFG_LOG_SUPPORTED is enabled.
Best Regards.
STTwo-32
‎2025-05-06 12:55 AM
‎2025-05-06 1:32 AM
Hello @cvs_dk
Dev team is working on the correction. It will be added on the future versions of the STM32CubeMX (I can't commit on a specific version for now).
Best Regards.
STTwo-32
