2022-11-24 8:45 AM
I have a project that use the STM32WLE5CCU6 and I want to make a variation of this project without RF communication.
Can you suggest me a reference to replace this MCU taking advantage of existing firmware without major changes. Preferably cheaper.
2022-11-24 11:49 AM
I don't think there is a software or pin compatible equivalent part.
CubeMX should have a pin matching tool
2022-11-24 12:19 PM
Correct, there is currently no pin-compatible MCU for the STM32WLE5 - a WLE5 without RF frontend, so to speak. The pins of other STM32 in UFQFPN48 are arranged completely differently, even the OSC pins for the crystals, NRST and the VDD/VSS pins are located elsewhere, not to mention the GPIOs.
Good luck anyway!
/Peter
2022-11-28 7:26 AM
Hello @DCarv,
I think the How to find compatible devices for an MCU? STM32G473CB as example article can help you finding the convenient device from the ST portfolio for your application.
Thank you.
Chahinez.
2022-11-28 7:32 AM
Thank you all
