BLE communication doesn't reach to specific state EVT_LE_PHY_UPDATE_COMPLETE
Lmali.1
I develop on both Nucleo-WB55 and my own board with STM32WB55CG.
When I use the Nucleo, everything works fine.
When I use my own baord, I see the device in my smartphone application but I can't connect.
I began to dig in and I found that when I use Nucleo, while connecting to smartphone, the software runs thru state EVT_LE_PHY_UPDATE_COMPLETE.
But when I run on my own board the software doesn't reach to this state.
Why is this different?
I believe I'm using with the same stm32wb5x_BLE_Stack_fw.bin.
Thanks,
Lior Malik
Lmali.1
I found the problem.
Because I work with internal oscillator for the BLE, the define CFG_BLE_LSE_SOURCE must be set to 1 for internal source.
Lmali.1
Remi QUINTIN
​Perfect!!
