attempts to connect to the gateway
IngSerio
Good morning,
I am using an STM32 WL55JC1 starting from the end node example.
I am unable to figure out in the code how to set how long or how many tries it makes before it stops trying to connect to the gateawy.
Could you please point me to this information?
Thank you very much,
Roberto
4 REPLIES 4
IngSerio
Has anyone realized where they can manage this aspect?
Thank you,
Roberto
STTwo-32
Hello @IngSerio
I suggest you take a look at the function on the joining context available on the lora_app.c of the LoRaWAN_End_Node example.
Best Regards.
STTwo-32
good morning, i have analyzed it but no solution to my question. i have reinserted a "forceRejoin" in case of connection failure but after a while anyway it stops trying.
If you could be more specific it would be helpful.
Thank u
Thank u
I stand corrected, the example I am starting from is.
"lorawan_end_node_FREERTOS" sorry for the inaccuracy
Roberto
