About the radio frequency parameters and distance of WL33.
‎2025-01-15 7:36 AM
Dear ST experts.
We are a module manufacturer. We have designed a module based on WL33. We have been using ST's dk board for verification. However, when we tested the distance, the original dk board was about 200 meters. With a 20dbm and -12X sensitivity, we have high expectations for this chip. Do you have ST distance test reports and parameters?
2. If our deviation is <2.5Khz, does it mean that we need to replace the TCXO?
B.R. Weili Wang.
STM32WL series
‎2025-01-24 2:59 AM
Hello Weili,
I propose to evaluate the performances of two RF settings:
First RF configuration:
- Data rate=200 kbps
- Frequency deviation = 100 kHz
- Channel filter= 400 KHz
- DSSS = 16
Second RF configuration:
- Data rate=100 kbps
- Frequency deviation = 50 kHz
- Channel filter= 200 KHz
- DSSS = 16
Saverio
‎2025-01-24 3:08 PM
Hi Saverio.
Regarding the DSSS setting, is it the Spread Factor in the GUI?
‎2025-01-28 1:46 AM
Hello Weili,
Yes, It is the Spread Factor.
Saverio
- « Previous
- 1
- 2
- Next »
