Using CPP Exceptions in touchgfx application
‎2020-03-27 1:32 AM
Our embedded application heavily uses CPP exceptions. CPP exception support is enabled in IAR under Options -> cpp options -> Enable exceptions . I am trying to integrate the touchgfx library with our embedded application based on STM32H743I MCU. Based on touchgfx article my understanding is that touchgfx library is created with compiler option -fno-exceptions i.e.without exception support. IAR linker generates an error for this
Error[Li009]: runtime model conflict: Module Application.o(touchgfx_core_release.a) specifies that '__CPP_Exceptions' must be 'Disabled', but module Ads1256.o has the value 'Used' .
Is there a variant of touchgfx library created without compiler option -fno-exceptions. This will allow us to link the touchgfx lib with our embedded application and keep using the cpp exceptions.
https://touchgfx.zendesk.com/hc/en-us/articles/206116381-Using-other-IDEs-with-TouchGFX
TouchGFX
‎2020-04-27 2:45 AM
Sincerest apologies! I created the lib but forgot to update this thread! -_-
‎2020-03-31 7:19 AM
Hi @STang.1​,
There is no such variant, but i could be persuaded to create one for you
/Martin
‎2020-03-31 4:11 PM
Hi Martin,
Thanks for your reply. I thought this would be a common requirement for others as well. For me this is a deciding factor between emWin and TouchGFX. I have a big list of pros for TouchGFX, but not being able to use CPP exceptions is something that will not pass the software architecture review. Can you please consider creating a variant with CPP exceptions enabled? We are okay if touchgfx does not catch exceptions thrown by application, we can work around that.
‎2020-04-01 2:02 AM
It's no problem : ) It's good to have these types of inputs and it's probably the first time someone has asked for it, actually. It's on my list now and i'll update this thread.
/Martin
‎2020-04-26 4:59 PM
Hi Martin,
Any update on this?
‎2020-04-27 2:45 AM
‎2020-04-27 2:46 AM
It's created with EWARM 8.42,1 - TouchGFX Version 4.13.0.
‎2020-04-27 6:50 PM
Just update this thread or PM me directly when you can verify the library. Thanks!
‎2020-04-27 8:39 PM
@Martin KJELDSEN​
Thanks for the library. I can confirm that I am successfully able to link the new touchgfx lib with my application with cpp exceptions enabled.
Do you plan to include this variant of the library in future touchgfx release?
Snehal
‎2020-04-28 12:47 AM
That's great! About including it - There are a lot of different permutations of libraries for various compilers - I think we'll have to discuss this internally. But if it's something people use a lot then definitely.
/Martin
