Use ITCM for dynamic Bitmap (TouchGFX 4.18)
MarcoSilenzi
Hello, I'm using an STM32H750 and I need to implement a single small dynamic bitmap, but I have only ITCM RAM available. I read and made all the code from the article
https://support.touchgfx.com/docs/development/ui-development/touchgfx-engine-features/dynamic-bitmaps
but the funcion Bitmap::dynamicBitmapCreate return INVALID.
The question is: is it possible to use ITCM for this purpose? I'm using IAR 8.32
Thank you
This discussion has been locked for participation. If you have a question, please start a new topic in order to ask your question
MarcoSilenzi
I forgot to have SRAM 1-2-3 available and they works perfectly for my purpose.
Thank you
3 REPLIES 3
MarcoSilenzi
Solved, please close the post
Lina_DABASINSKAITE
Community manager
Community manager
Hello @MarcoSilenzi ,
Can you share the solution? After that I am happy to close the post.
Regards,
Lina
MarcoSilenzi
Thank you
