Updating elements of ScrollList
EEuge
Senior
Hello! I create CustomContainer1, added to it textArea1 with wildcard buffer
I added CustomContainer1 to ScrollList2 and compiled project
I added button1 and want to change item â„–2 in CustomContainer1 by clicking button1
I added Iteraction to button1 - clicking is calling ChangeItemName() function.
In CustomContainer1.cpp :
void CustomContainer1::SetItemName(uint16_t data)
     Unicode::snprintf(textArea1Buffer, 20, "%d", data);
		textArea1.setWildcard(textArea1Buffer);
	textArea1.resizeToCurrentText();
	   textArea1.invalidate();
In Screen1View.cpp:
void Screen1View::scrollList2UpdateItem(CustomContainer1& item, int16_t itemIndex)
 uint16_t item_name_value;
 item_name_value=itemIndex;
 item.SetItemName(item_name_value);
void Screen1View::ChangeItemName(uint16_t number)
 What I have to add to ChangeItemName() if I want to change some Item of ScrollList ?
CustomContainer1.SetItemName(1); - error
7 REPLIES 7
EEuge
Senior
I found solution!!
	(*(CustomContainer1*)scrollList1ListItems.getDrawable(ItemNumber)).SetItemName(ItemName);
EEuge
Senior
Still have problem
uint8_t str[] = "FileName";
		Unicode::snprintf(textArea1Buffer, 20, "%s", str);
Can't write any text.
uint16_t data;
output digits.
How to write text?
EEuge
Senior
Solved!
I didn't set wildcard range.
But.... still have problem
Unicode::snprintf(textArea1Buffer, 20, "%s","RB
prints "B".
Unicode::snprintf(textArea1Buffer, 20, "%s","RBJ");
prints "?J?"
Only last character and "?"
Why?
PBull
try this:
	const char str[] = "FileName";
	Unicode::strncpy(textArea1Buffer, str, 20);
Best regards,
Peter
Thanks!!!
Your code works!!!!
PBull
your code doesn't work because %s needs a zero-terminated UnicodeChar list, but you passed a const char ("RBJ").
You have to copy your string to a UnicodeChar list and pass your UnicodeChar buffer to snprintf:
	Unicode::UnicodeChar buffer[20];
	const char str[] = "RBJ";
	Unicode::strncpy(buffer, str, 20);
	Unicode::snprintf(textArea1Buffer, 20, "%s", buffer);
Good! It works!!!
Thanks!
