2022-08-02 11:20 AM
I'm using the version 16.1 of TouchGFX and when I generate the project on the simulator I get these error messages when I try to run the code in VS :
I generate the project with the following text config:
Any help is more than welcome.
2022-08-08 2:50 AM
Hello @GMeur ,
To be sure, did you already try to generate code with TouchGFX 4.20.0 ?
/Yoann
